USECOMMUNICATOR system variable
Use Communicator
Shows if the Communicator for BricsCAD is in use. If active, also shows the license type.
  • 0: no license, Communicator for BricsCAD import and export formats are not available.
  • 1: trial, runs Communicator for BricsCAD in trial mode, expiring after 30 days.
  • 2: full, runs the full Communicator for BricsCAD import-export set.
If the license is changed, the new level comes into effect after restarting the program.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 2
Default value:
1
Possible options:
0: Not using Communicator
1: Communicator in use - on trial
2: Communicator in use - fully licensed
