USENEWLOOKFROM system variable
Use the new LookFrom
Enables the new version of LookFrom.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0): Turns off the new version of LookFrom
On (1): Turns on the new version of LookFrom
Related commands
  • LOOKFROM command
Related information
  • The LookFrom control
  • Using the LookFrom control
