VIEWMODE system variable
View mode (Read Only)
The current viewport's View mode.
- If off, the front clipping plane passes through the camera point (vectors behind the camera are not displayed) unless front-clipping is off.
- If Front clip not at eye is on, the FRONTZ system variable controls the front clipping plane.
| Type: | Short |
| Saved in: | Drawing |
| Range: |
0 to 31 |
| Possible options: |
0: Turned off 1: Perspective view active 2: Front clipping on 4: Back clipping on 8: UCS Follow mode on 16: Front clip not at eye |
