VOLUMEPREC system variable
Volume precision
Specifies the number of decimal places displayed for volumes when the volume bit of PROPUNITS is on. If negative, LUPREC (Linear Unit Precision) is used.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: |
-1 to 8 |
| Default value: |
-1 |
| Possible values: |
-1: Use LUPREC 0 1: 0.0 2: 0.00 3: 0.000 4: 0.0000 5: 0.00000 6: 0.000000 7: 0.0000000 8: 0.00000000 |
