VOLUMEUNITS system variable
Volume units
Controls a list of units used to display volume, if volume properties are formatted with the PROPUNITS system variable.
If empty, all volumes match the drawing.
Note: The string contains a space-separated list of unit abbreviations.
BricsCAD only
| Type: | String |
| Saved in: | Registry |
| Default value: |
in ft mi µm mm cm m km |
