VOLUMEUNITS system variable
Volume units
Controls a list of units used to display volume, if volume properties are formatted with the PROPUNITS system variable.
If empty, all volumes match the drawing.
Note: The string contains a space-separated list of unit abbreviations.
BricsCAD only
Type:
String
Saved in:
Registry
Default value:
in ft mi µm mm cm m km
