VPMAXIMIZEDSTATE system variable
Viewport maximized (Read Only)
Displays a value to indicate if the viewport is maximized.
Note: You cannot plot or publish when the viewport is maximized.
This system variable is available only at the Command line.
| Type: | Boolean |
| Saved in: | Not saved |
| Default value: | Off |
| Possible values: |
Off (0): Viewport is not maximized On (1): Viewport is maximized |
