VTFPS system variable
View transition minimum FPS
Controls the minimum FPS required to enable animated view transitions.
Values between 1 and 30 are accepted.
The default value is 7, which means that the redraw time should take less than 143 (=1000/7) milliseconds. If the computer is not capable to redraw the view fast enough, no animation will be available.
| Type: | Short |
| Saved in: | Registry |
| Range: |
1 to 30 |
| Default value: |
7 |
