WARNINGMESSAGES system variable
Warning messages
Controls which warning messages are displayed.
BricsCAD only
| Type: | Long |
| Saved in: | Preference |
| Default value: |
1048575 |
| Possible options: |
1: When 3D context with hardware rendering switched off is selected 2: When tool property are modified in the Customize dialog box 4: When sheet custom properties are deleted 8: When entities are moved to frozen or off layer 16: When saving to previous version that does not support certain entities 32: When a drawing is opened and modified attachments are detected 64: When a new layer, that does not match the current layer filter, is created 128: Render: Tile sizes between 4 and 127 are processed as 128 256: When a category mass is expanded in the Properties panel 512: When an item in the Customize dialog box is deleted 1024: On publish: Save sheet list 2048: When layouts in Page Setup Explorer are deleted 4096: When mass property calculations will take a long time 8192: When entering the Array Edit mode 16384: When there are incompatible units 32768:When a block definition modification will cause all related block references to update 65536: When a Data Link has changed - tables that use this link may need to be updated 131072:When VIEWBASE is used for architectural drawings 262144: When a closed category in the Properties panel is expanded 524288: When an empty category in the Properties panel is removed |
