WHIPTHREAD system variable
Whip thread
Controls if the REGEN and REDRAW commands use multithreading, if the machine has multiple processors (Not yet supported).
When multithreaded processing is used for redraw operations (value 2 or 3), the order of entities specified with the DRAWORDER command is not guaranteed to be preserved for display but is preserved for plotting.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 3 |
| Default value: |
0 |
| Possible options: |
0: No multithreading 1: Regenerative multithreading 2: Redraw multithreading |
