XFADECTL system variable
Reference editing fade control
Controls the transparency for XRefs during edit mode.
This system variable affects only the entities that are not being edited in the reference.
Values between 0 and 90 are accepted.
- A value of zero means fully opaque.
- A value of 90 means maximum transparency.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 90 |
| Default value: |
50 |
