XLOADCTL system variable
XRef load control
Controls XRef demand loading and if a copy or the original drawing is opened (Not yet supported).
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 2 |
| Default value: |
1 |
| Possible options: |
0: Turn off demand-loading; the entire drawing is loaded 1: Turn on demand-loading; referenced drawings are kept open and locked 2: Turn on demand-loading; copies of referenced drawings are opened and locked; referenced drawings are not locked |
