Complete guide to migrating custom files from a previous BricsCAD version or a different computer
1. Overview of custom files to migrate and their paths
BricsCAD uses a variety of files that store your personal settings, customizations, profiles, and application data to assist you in creating your drawings.
| File type | Extension | Found in | Path | |
| Partial customization files |
Support folder |
| Linetypes | LIN | |||
| Hatch patterns | PAT | |||
| Tool palettes |
| Command aliases | PGP | |||
| Shape files | SHP | |||
| Drawing templates | DWT | Templates folder |
| Plot files | Plot Styles |
PlotStyles folder |
| Plot Config |
PlotConfig folder |
| LISP files | LSP | Support folder |
Use the SETTINGS command to configure how BricsCAD locates and loads custom files. In the Settings dialog, you can define all support file paths, including folders for linetypes, shapes, fonts, Xrefs, plotters, and other resources required during migration.
Use the CUSTOMIZE command to modify how BricsCAD user interface behaves. In the Customize dialog box, you can change the actions of interface elements such as menus, ribbons, toolbars, and mouse buttons, ensuring that migrated custom files are properly integrated into your workspace.
| Migration method | Source | What is migrated | Considerations |
| Manual migration of custom files |
Individual customization files, such as CUI/CUIX files, LISP applications, FAS/VLX files, templates, plot styles, linetypes, scripts, icons, and other support files. | Provides full control over what is transferred. Make sure that all dependent files and referenced resources are also migrated. |
| User profile migration |
User settings and preferences stored in a profile (ARG file), including workspace settings, user interface configuration, and other profile-related options. | Importing a profile does not automatically transfer referenced customization files. Any associated customization resources must be migrated separately. |
| User file migration |
Note: Available only when updating BricsCAD on the same computer.
User files stored in BricsCAD user folders that are detected during an upgrade | The BricsCAD user file manager dialog box allows you to keep customized files or replace them with the updated versions provided by the new release. |
- Manual migration of custom files
- Use the manual migration method when you want to transfer specific customization resources from AutoCAD®, a previous BricsCAD version, or BricsCAD installed on a different computer. Manual migration involves locating, copying, and loading individual customization files to the current BricsCAD installation.
- User profile migration
- Use the user profile migration method when you want to transfer specific customization resources from the same BricsCAD version installed on a different computer.
Use the PROFILEMANAGER command to manage the settings and preferences that define your BricsCAD working environment. In the User Profile Manager dialog box, you can create, load, export, and import user profiles, helping you migrate your customized environment.
- User file migration
- Use the user file migration method when updating BricsCAD on the same computer. During the first launch after the update, the BricsCAD User File Manager compares files in the user file folders with the corresponding files in the UserDataCache folder. If differences are detected, you can choose whether to keep your customized files or replace them with the updated versions provided by the new version of BricsCAD.
2. Migrating user profiles
In BricsCAD, settings that define the drawing environment can be saved in a user profile. User profiles can store settings such as the current workspace, user interface configuration, system variable settings, project settings, recent paths, and other user preferences. Multiple user profiles can be created to support different drawing types, workflows, or user preferences.
To migrate user profiles, export the profile to an ARG file and import it into the current BricsCAD installation.
Go to BricsCAD on the computer where the user profile is. Launch the PROFILEMANAGER command to open the User Profile Manager dialog box. Select the desired profile and click Export... to save the ARG file.
Then, go to the same version of BricsCAD and launch the PROFILEMANAGER command to open the User Profile Manager dialog box. Click Import... and select the ARG file.
3. Migrating custom files
3.1 Migrating partial customization files
CUI or CUIX files can load and save full or partial custom workspaces. Only partial customization files should be migrated. Loading a partial CUI file adds custom menus, toolbars, ribbon elements, and other interface customizations to the existing user interface. When you install BricsCAD, the default CUI file is copied to the Support folder.
- A CUIX file is a zipped package that contains all files required by the user interface. When loaded, it is automatically converted to a CUI file. Bitmap resources contained in a CUIX file are copied to a .RESZ resource file, which can be used as an alternative to a resource DLL. Supported image formats include BMP, JPG, PNG, ICO, GIF, TIFF, XBM, and XPM.
- When migrating a partial customization file, make sure that any referenced support files, custom icons, scripts and LISP routines are also transferred and that their file paths are correctly configured in BricsCAD.
Go to the previous version of BricsCAD or to BricsCAD on a different computer and launch the CUSTOMIZE command. In the Customize dialog box, select the desired partial customization file to display its path. Copy and store the file as needed.
Then, go to the current version of BricsCAD and launch the CUSTOMIZE command to open the Customize dialog box. From the File menu, choose Load partial CUI file... to open the Choose a customization file dialog box. Select and load the desired partial customization file.
3.2 Migrating custom linetypes
LIN files store linetype definitions. BricsCAD provides two default LIN files that you can customize: default.lin for imperial linetypes and iso.lin for metric linetypes. To migrate custom linetypes, copy the required linetype definitions from these files. You can also store custom linetypes in a separate LIN file and load it in BricsCAD.
To migrate custom linetypes, locate each file, copy the custom linetype definitions or the custom LIN file, and save them in the corresponding BricsCAD file.
- Migrating imperial or metric custom linetypes
- Go to the Support folder in the previous version of BricsCAD or in BricsCAD on a different computer. Open with a text editor the default.lin file for imperial custom linetypes or the iso.lin file for metric custom linetypes and copy the linetype definition.
Then, in the current version of BricsCAD go to the Support folder. Open in a text editor the default.lin file for imperial custom linetypes or the iso.lin file for metric custom linetypes. Paste the definition of the custom linetype at the end of the file, then save and close it.
- Migrating custom LIN Files
- Go to the current version of BricsCAD, run the LINETYPE command, and choose New to open the Load Linetypes dialog box and import your custom LIN file.
It is recommended to store the custom LIN files in BricsCAD Support folder.
3.3 Migrating custom hatch patterns
PAT files store the definition of the hatch patterns. There are two default PAT files, one for imperial hatch patterns and another for ISO hatch patterns. Custom hatch patterns can also be stored in an alternative PAT file.
To migrate custom hatch patterns, locate each file, copy the custom hatch patterns definitions or the custom PAT file, and save it in the corresponding BricsCAD file.
- Migrating imperial or metric custom hatch patterns
- Go to the Support folder in the previous version of BricsCAD or in BricsCAD on a diffrent computer. Open in a text editor the default.pat file for imperial custom hatch patterns or the iso.pat file for metric custom hatch patterns and copy the hatch patterns definition.
Then, in the current version of BricsCAD go to the Support folder. Open in a text editor the default.pat file for imperial custom hatch patterns or the iso.pat file for metric custom hatch patterns. Paste the definition of the custom hatch patterns at the end of the file, then save and close it.
- Migrating custom PAT files
- Go to the Support folder in the previous version of BricsCAD or in BricsCAD on a diffrent computer. Copy and store the custom PAT files as needed. Then, choose one of the following:
- (Recommended) In the current version of BricsCAD go to the Support folder and save there the custom PAT files.
- Open the current version of BricsCAD. Add the location of your custom PAT files to the Support file search path section in the Settings dialog box (SRCHPATH system variable).
3.4 Migrating custom drawing templates
Drawing templates are DWT files that stores settings specific to the drawing and project requirements, such as units, layers, styles, layouts, etc.
To migrate custom drawing templates, locate each file, copy and save it in the corresponding BricsCAD folder.
Go to the previous version of BricsCAD or to BricsCAD on a different computer. Launch the TEMPLATEFOLDER command to find the location of the drawing template file and copy the files.
Then, in the current version of BricsCAD launch the TEMPLATEFOLDER command to open the folder where the drawing template files are stored. Paste the files.
3.5 Migrating custom plot files
Custom plot styles are stored in CTB or STB files. Plotter configurations are stored in PC3 files, and plotter model parameters associated with a PC3 are stored in PMP files.
- CTB and STB files are fully compatible. A drawing can use either CTB or STB plot styles, so the plot style table is displayed based on the current drawing plot style mode (see the CONVERTPSTYLES command article).
- In BricsCAD, PC3 plotter configuration files are supported only for Windows system printers, while AutoCAD® supports additional printer configuration types.
- Some PC3 configurations also require their associated PMP file when migrated.
To migrate custom plot files, locate each file, copy the files and save them in the corresponding BricsCAD file.
- Migrating Color-Dependent Plot Style Table (CTB) or Named Plot Style Table (STB)
- Go to the previous version of BricsCAD or to BricsCAD on a different computer. Launch the STYLESMANAGER command to open the PlotStyles folder and copy the files.
Then, go to the current version of BricsCAD and launch the STYLESMANAGER command to open the PlotStyles folder and paste the files.
- Migrating Plotter Configuration File (PC3)
- Go to the previous version of BricsCAD or to BricsCAD on a different computer. Launch the launch the PLOTTERMANAGER command to open the PlotConfig folder and copy the files.
Then, go to the current version of BricsCAD and launch the PLOTTERMANAGER command to open the PlotConfig folder and paste the files.
- Migrating Plotter Model Parameters (PMP)
Then, go to the current version of BricsCAD and launch the PLOTTERMANAGER command to open the Plotters folder. Open the PMP Files folder and copy the files.
3.6 Migrating custom tool palettes
BricsCAD supports importing tool palettes from XTP, ATC and BTC files, and tool palette groups from XPG and BWS files. Tool palettes can be exported to BTC files, and tool palette groups to XPG files.
BricsCAD stores tool palettes in BTC files and indexes all existing palettes in the BcTpCatalog.btc file. When you create or import a new palette, BricsCAD updates the catalog and automatically generates a separate BTC file that contains the palette’s content. All palette files are stored in the default Tool Palettes folder inside the Support directory.
To migrate custom tool palettes, export each file and import it into BricsCAD.
Go to the previous version of BricsCAD or to BricsCAD on a different computer and launch the TOOLPALETTES command to open the Tool Palettes panel. Right-click the panel and choose Customize Palettes... to display the Customize dialog box. Then, right-click the custom palette or palette groups you want and select the Export option to open the Export Palette or Export Palette Group dialog box. Save the custom palette file as an XTP file or the custom palette group as an XPG file.
Then, go to the current version of BricsCAD and launch the TOOLPALETTES command to open the Tool Palettes panel. Right-click the panel and choose Customize Palettes... to display the Customize dialog box. Then, right-click any palette and select the Import option to open the Import Palette dialog box. Choose the XTP or XPG file you want to import.
3.7 Migrating custom command aliases
Command aliases are alternative names for commands, and they are saved in a PGP file.
To migrate custom command aliases, locate each file, copy the custom command aliases definitions, and save them in the corresponding BricsCAD file.
Go to the Support folder in the previous version of BricsCAD or in BricsCAD on a different computer. Open the default.pgp file with a text editor and copy the custom command aliases definition.
Then, in the current version of BricsCAD go to the Support folder and open default.pgp file in a text editor. Paste the definition of the custom command aliases at the end of the file, then save and close it.
3.8 Migrating custom shape files
SHX files store the definition of the fonts and SHP files store the definition of the shapes. These files are usually stored in the Support folder.
To migrate custom command aliases, locate each file, and copy both the SHP and SHX files to the BricsCAD Support folder.
Go to the Support folder in the previous version of BricsCAD or in BricsCAD on a different computer. Copy both the SHP and SHX files.
Then, in the current version of BricsCAD go to the Support folder and paste the SHP and SHX files.
3.9 Migrating LISP files
LISP (procesamiento de listas) es un lenguaje de programación interpretado que se utiliza para automatizar tareas, crear comandos personalizados y ampliar BricsCAD la funcionalidad. Las rutinas LISP pueden interactuar con BricsCAD comandos, variables del sistema, cuadros de diálogo y entidades de dibujo.
BricsCAD es compatible con AutoCAD® AutoLISP, por lo que puede cargar y ejecutar archivos LSP. Sin embargo, los formatos de archivo VLX y FAS son AutoCAD® archivos LISP cifrados específicos y BricsCAD no pueden cargar dichos archivos.
Para migrar rutinas LISP, localiza los archivos LSP deseados y luego cópielos y guárdalos en el archivo correspondiente BricsCAD. Los archivos LISP suelen almacenarse en la carpeta de Support (desde la carpeta de instalación), pero también pueden almacenarse en una carpeta añadida a la ruta de búsqueda de soporte usando la variable de sistema SRCHPATH.
Ve a la carpeta Support en la versión anterior o BricsCAD en BricsCAD otro ordenador. Abre con un editor de texto el archivo default.lin para tipos de línea personalizados imperiales o el archivo iso.lin para tipos de línea personalizados métricos y copia la definición de tipo de línea.
- Migrando ON_START. LSP o ON_DOC_LOAD. LSP
- Ve a la carpeta de Support en la versión anterior o BricsCAD en BricsCAD otro ordenador y abre en un editor de texto el archivo on_start.lsp o on_doc_load.lsp. Selecciona el contenido personalizado y cópialo.
A continuación, en la versión actual de BricsCAD vaya a la carpeta Support y cree un nuevo archivo de texto llamado on_start.lsp o on_doc_load.lsp. Pega el contenido personalizado y guárdalo.
- Migración de archivos DES cifrados
- Los archivos DES son archivos de aplicación BricsCAD cifrados creados con DEScoder.exe. Por lo general, se almacenan en la carpeta Support (de la carpeta de instalación) o en una carpeta añadida a la ruta de búsqueda de soporte mediante la variable de sistema SRCHPATH.
Para migrar archivos DES, localiza cada archivo, cópialo y guárdalo en el archivo correspondiente en la versión actual de BricsCAD.
Note: Al migrar archivos DES de una versión anterior BricsCAD , se recomienda verificar la funcionalidad de la aplicación. Si la aplicación no funciona como se espera, recrea el archivo DES volviendo a cifrar los archivos fuente originales con DEScoder.exe.
- Tras la migración, on_start.lsp se carga por sesión de forma predeterminada, pero también se puede cargar para cada dibujo si la variable de sistema ACADLSPASDOC se establece en 1. El archivo on_doc_load.lsp siempre se carga para cada dibujo.
- Otra forma de cargar sus rutinas LISP es mediante el comando APPLOAD. Después de ejecutar el comando, se muestra el cuadro de diálogo Cargar archivos de Aplicación para seleccionar los archivos de aplicación que desea ejecutar dentro de BricsCAD. La opción Carga automática especifica si un archivo se carga automáticamente o no en la siguiente sesión de BricsCAD (consulte el artículo del cuadro de diálogo Cargar archivos de aplicación para obtener más información).
La ruta del codificador DES es: C:\Archivos de programa\Bricsys\BricsCAD V26 en_US.
- Abra el codificador.
- Seleccione el archivo LISP en el campo Origen.
- Haga clic en el botón Convertir el archivo Lisp de origen seleccionado en un archivo DES cifrado, junto al campo Destino.
- Después de convertir el archivo DES, cópialo a BricsCAD la carpeta Support (desde la carpeta de instalación): %AppData%\Bricsys\BricsCAD\V26x64\en_US, o a una carpeta que hayas añadido a la ruta de soporte usando la variable de sistema SRCHPATH.
