Minimum system requirements and recommendations
System requirements and recommendations for Intel and AMD-based Microsoft Windows & Linux PCs, and Intel-based Apple Macs.
Supported Operating Systems |
Note: Windows 8.1 will reach the end of Microsoft’s Extended Support program
on 10 January 2023.
Note: Mac OSX is supported only on Intel-based hardware at this time.
Deprecated Operating Systems |
Note: we do not recommend running mission-critical CAD software on
unsupported operating systems, as your PC may become more vulnerable to
security risks.
Minimum CPU:
Recommended CPU:
The CPU with the highest single-thread performance rating will always excel with BricsCAD®. Additional CPU cores can be a bonus, because BricsCAD® supports the concept of ‘helper threads’ for many data- and calculation-intensive tasks. Note about Intel® Xeon® and AMD Ryzen™ Threadripper™ CPUs: these top-tier workstation CPUs support large on-chip memory cache, more PCIe® I/O lanes and multi-channel, high speed memory architectures. Will they help BricsCAD® run faster? Maybe. You will need to do testing in your specific environment, to determine if the additional cost of these systems is justifiable. |
Minimum System Memory: 8 GB |
Recommended System Memory:
For maximum performance, determine the memory configuration of your PC and ensure that each memory channel on the motherboard is populated with at least one memory module (SIMMs/DIMMs). Note: the number of available memory channels may not correlate 1:1 with
the number of RAM sockets on your PC’s motherboard. Questions? Please
check with your hardware supplier before you buy system memory.
Minimum Disk Space: 2 GB for BricsCAD® Últimate, installed |
Recommended Disk Space: (As needed) |
We recommend Solid-State Drives (SSDs) as system drives, for both BricsCAD® and Windows. Drawings and support files can reside on slower mechanical hard disk drives, if necessary. Note: solid-state disks can be up to 10x faster reading and 20x faster
writing data than a mid-range hard disk drive (for example Seagate
Barracuda 5.4k RPM, SATA 6.0).
Minimum Display System:
Recommended Display System:
On Microsoft Windows systems, most graphics cards & GPUs from NVIDIA, AMD and Intel® are supported. On Linux systems, most graphics cards and GPUs from NVIDIA and AMD are supported. On Mac systems, native Apple display hardware is supported. BricsCAD®’s non-wireframe display modes are generated by RedSDK technology from Redway3D®. For maximum RedSDK performance in these modes, a GPU is required. Note: We suggest that you install the latest drivers available for your
display hardware, as recommended by the manufacturer.
Note to Linux users: Hardware acceleration of 3D graphics on Linux systems is NOT supported on:
For more information about supported graphics hardware for BricsCAD®, see the Redway3D GPU chipset reference page. |
