ESCALAOBJETO comando
Añade o elimina factores de escala.
Ícono:
Descripción
Añade o elimina factores de escala utilizados con entidades anotativas a través del cuadro de diálogo Escala de entidad de anotación.
Nota: La escala anotativa ajusta los factores de escala de los elementos anotativos, como el texto y los patrones de sombreado, para que coincidan con la escala de la parcela.
The Annotation Entity Scale dialog box allows you to add or remove scale factors used with annotative entities.
Entity Scale List
Shows all the scales supported by the selected annotative entities.
- Add
- Adds annotation scale factors to the selected entities.
- Delete
- Removes annotation scales from the selected entities.Nota: This option is available if there is more than one annotation scale attached to the entity.
Options
- List all scales for selected entities
- Lists all the scale factors of the selected entities.
- List scales common to all selected entities only
- Lists only the scale factor shared by the selected entities.Nota: At least two entities must be selected.
