Geographic location dialog box
The Geographic Location dialog box allows you to set the geographic location of the drawing by applying the longitude and latitude to a point in the drawing.
- GIS Coordinate System
- Latitude / Longitude
- Position
- North direction
- Elevation
Reports the GIS system being used by the drawing.
Note: Click the browse icon to change the system.
- Store geographic location information in drawing
- When checked, a red dot indicates the position in the drawing.
- Use Map Grid coordinate system
- Uses the location data from the GIS Coordinate System.
- Choose Location
- Specifies the graphic location trough the Choose Geographic Location dialog box.
- Degrees Minutes Seconds Lat/Long
- Displays the location in a Degrees, Minutes and Seconds format.
- Decimal Lat/Long
- Displays the location in a decimal format.
- Latitude
- Sets the altitude. The valid range is 0 to 90.
- Longitude
- Sets the longitude. The valid range is 0 to 180.
- Time zone
Specifies the time zone from the Time Zone drop list.
Note: This setting is saved to the TIMEZONE system variable.
Position
Specifies the position of the location in the drawing by entering coordinate values.
Note: You can also select a specific point in the workspace to
set the position.
North direction
Specifies the angle of the sun from north, in the context of the world coordinate system.
Note: The setting is saved to the NORTHDIRECTION system
variable.
Elevation
Specifies an elevation for the long-lat point. The value can be positive or negative.
