Optimize 2D lines dialog box
The Optimize 2D Lines dialog box allows you to correct inaccuracies in drawings, such as small gaps between lines or near vertical, horizontal and diagonal lines. It includes 4 areas.
- Line Source
- Reference angles
- Options
- Tolerances
Line Source
Specifies the lines in the drawing to work with.
- Select lines in drawing
- Selects line entities in drawing trough the model space. Press enter when done.
- Entire drawing
- All entities in the drawing are taken into account.
Reference angles
Specifies the angles for which lines will be corrected.
- Horizontal
- Corrects near horizontal lines according to the angle tolerance.
- Vertical
- Corrects near vertical lines according to the angle tolerance.
- Diagonal
- Corrects near 45° lines according to the angle tolerance.
- Live feedback
- Highlights the lines which match the selected options.
Options
- Close gaps
- Closes small gaps between line entities when checked.
Tolerances
Specifies the tolerance value.
