Render dialog box
The Render dialog box allows you to generate a photo-realistic rendering using materials and lights.
- Render destination
- Output size
Render destination
Specifies where the render will appear.
- Viewport
- Generates the render in the current viewport.
- Window
- Generates the render in a new window.
- File
- Saves the render to a file. Selecting the three dots opens the render output file dialog box.
Output size
Specifies the size of the rendering, in pixels. Larger sizes provide more detail but take longer to render.
- Width
- Specifies the width of the rendering, in pixels.
- Height
- Specifies the height of the rendering, in pixels.
- Same as viewport size
- Matches the output size or the size of the output window to the current viewport size.
