Select item to attach to this DWG
The Select item to attach to this DWG dialog box enables you to attach point cloud files that have already been processed and stored in the cache.
- Cache used
- Available
- Dataset
- Size
- OK
- Cancel
Cache used
Specifies the total amount of used cache.
Available
Specifies the total amount of available cache. The available cache is controlled by the POINTCLOUDCACHESIZE system variable.
Dataset
Displays a list of cached point cloud files including their names and locations. You can select a cached file from the list to attach to the current drawing.
Size
Displays the amount of cache used for each point cloud file.
OK
Displays the Attach point cloud dialog box where you can specify how to attach the selected point cloud file to the current drawing.
Cancel
Closes the dialog box without attaching a point cloud file.
