Set viewpoint dialog box
The Set Viewpoint dialog box allows you to set the current 3D viewport or plan view.
- Command reference
- Horizontal
- Vertical
- Angle Preset
- Plan
- Previous
Command reference
Opens the Bricsys Help article about the DDVPOINT command.
Horizontal
Specifies the horizontal angle from the X - axis. Click a preset angle or type a value in the Horizontal field.
Click at 0°, 45°, 90°, 135°, 180°, 225°, 270° or 315° in the inner circle. The shape
of the arrow indicates whether the view is horizontal
or at an angle
Vertical
Specifies the vertical angle from the XY plane. Click a preset angle, or else type a value in the Vertical field.
Click in the inner half circle. (1) View direction is horizontal. (2) View direction is 45° down (not available if PresetAngle = 45°).
(1)
(2)
View direction is 45° down, except for 0°, 90°, 180° and 270° horizontal angles, which generate orthographic views: front, back, left and right. (3) First select the horizontal arrow, then (4) click the 45° down arrow.
(3)
(4)
Angle Preset
Sets markers at 5, 15, or 45 degrees; default = 45.
Plan
Reverts the 3D viewpoint to 2D plan view.
Previous
Reverts to the previous viewpoint.
