SAVEFORMAT (variable système)
Format enregistrement
Spécifie le format d’enregistrement par défaut d’un dessin.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
1 à 39 |
| Default value: |
4 |
| Possible values: |
1: DWG 2018 2: DXF 2018 3: DXF 2018 binaire 4: DWG 2013 5: DXF 2013 6: DXF Binaire 2013 7: DWG 2010 8: DXF 2010 9: DXF 2010 binaire 10: DWG 2007 11: DXF 2007 12: DXF 2007 binaire 13: DWG 2004 14: DXF 2004 15: DXF 2004 binaire 16: DWG 2000 17: DXF 2000 18: DXF 2000 binaire 19: DWG R14 20: DXF R14 21: DXF R14 binaire 22: DWG R13 23: DXF R13 24: DXF R13 binaire 25: DWG R11/R12 26: DXF R11/R12 27: DXF R11/R12 binaire 28: DXF R10 29: DXF R10 binaire 30: DXF R9 |
