ELEV command
Changes the elevation and thickness of selected objects.
Icon:
Changes the elevation (as measured from the x,y-plane in the z direction) and thickness (as measured from the elevation) of selected entities.
Options within the command
- New current elevation
- Specifies the elevation above or below the x,y-plane. For a negative elevation, a negative value can be entered.
- New current thickness
- Specifies the thickness. Enter a negative value for thickness that are drawn downwards.
