FILLET command
Fillets intersections; joins intersecting lines with an arc of any suitable radius.
Icon:
Alias: F
Sets a radius value for fillet between two entities.
The entities could be:
- Lines, including parallel lines
- All vertices of a single 2D polyline; two polylines cannot be filleted
- Rays, including parallel rays
- Infinite lines, including parallel infinite lines
- Arcs
Note: Press and hold the Shift key when select the second
entity to create a corner (radius = 0). The selected entities are extended or
trimmed at the intersection point. The selected part of the entities is
kept.
Note: If the second entity is parallel to the first entity the
entities are connected by a semicircle. If the parallel entities are not of
equal length, then the second entity is extended or trimmed when Trim Mode =
Trim.
Options
- fillet Settings
- Displays the Chamfer/Fillet section of the Settings dialog box:
- Polyline
- Fillets the all vertices of a polyline.
- Radius
- Toggles edge mode.
- Trim
- Sets the trim mode for chamfers and fillets:
- Undo
- Undoes the last fillet when in Multiple mode.
- Multiple
- Lets to create additional fillets using the same settings without having to restart the command.
