MAPCONNECT command
MAPCONNECT command
Allows to set up a connection with a Web Map Service.
Displays the Map connect dialog box.
Note: Before adding map data to a drawing, you must run the GEOGRAPHICLOCATION command to define the geographic location of the drawing.
Parent topic: Riferimento Comandi
Related commands
  • Comando POSGEOGRAFICA
  • Comando IMMAGINE
Related information
  • Finestra di dialogo Connessione Mappa
  • Finestra di dialogo Posizione Geografica
