PLOTTERMANAGER command
Create and edit plotter settings.
Opens a generic system dialog box PlotConfig where you can choose a plotter configuration file or where you can create and edit customized parameter PC3 files for printers and other output devices.
Parent topic: Riferimento Comandi
  • CONVERTCTB command
  • CONVERTSTILIST
  • IMPOSTAPAG
  • PLOTSTYLE command
  • PRINT
  • STAMPA
  • STYLESMANAGER command
Related Information
  • Configurazione del Plotter
