SALVA
Apre la finestra di dialogo Salva Disegno Come.
Icona:
Alias: SA, SALVAURL
Descrizione
Apre la finestra di dialogo Salva Disegno Come per salvare i dati del disegno corrente in un file DWG, DXF, DWT o DWS.
I tipi di file disponibili per il salvataggio sono:
- AutoCAD 2018 (*dwg)
- AutoCAD 2018 ASCII DXF (*dxf)
- AutoCAD 2018 Binario DXF (*dxf)
- AutoCAD 2013 (*dwg)
- AutoCAD 2013 ASCII DXF (*dxf)
- AutoCAD 2013 Binario DXF (*dxf)
- AutoCAD 2010 (*dwg)
- AutoCAD 2010 ASCII DXF (*dxf)
- AutoCAD 2010 Binario DXF (*dxf)
- AutoCAD 2007 (*dwg)
- AutoCAD 2007 ASCII DXF (*dxf)
- AutoCAD 2007 Binario DXF (*dxf)
- AutoCAD 2004 (*dwg)
- AutoCAD 2004 ASCII DXF (*dxf)
- AutoCAD 2004 Binario DXF (*dxf)
- AutoCAD 2000 (*dwg)
- AutoCAD 2000 ASCII DXF (*dxf)
- AutoCAD 2000 Binario DXF (*dxf)
- AutoCAD Release 14 (*dwg)
- AutoCAD Release 14 ASCII DXF (*dxf)
- AutoCAD Release 14 Binario DXF (*dxf)
- AutoCAD Release 13 Drawing (*dwg)
- AutoCAD Release 13 ASCII DXF (*dxf)
- AutoCAD Release 13 Binario DXF (*dxf)
- AutoCAD Release 11/12 Drawing (*dwg)
- AutoCAD Release 11/12 ASCII DXF (*dxf)
- AutoCAD Release 11/12 Binario DXF (*dxf)
- AutoCAD Release 10 ASCII DXF (*dxf)
- AutoCAD Release 10 Binario DXF (*dxf)
- AutoCAD Release 9 ASCII DXF (*dxf)
- File Standards (*dws)
- Template Disegno (*dwt)
