TYPEDPLANS command
TYPEDPLANS command
Opens the BIM Typed Plans dialog box.
BricsCAD BIM
Icon:
Opens the BIM Typed Plans dialog box, listing all Typed Plans in the support folder. You will be able to customize drawing plans as well as the BIM Tags.
Parent topic: Riferimento Comandi
Related commands
  • BIMTAG command
Related information
  • Pannello Navigatore Progetto BIM
  • Finestra di dialogo Piani Tipo BIM
  • Lavorare con i Piano Tipo
