_QUADTABFLAGS system variable
Quad tab flags
Temporary setting used while new quad tab layout is being implemented. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
| Type: |
Short |
| Saved in: | Preference |
| Range: |
0 to 31 |
| Default value: |
12 |
| Possible options: |
1: Fixed width tabs 2: Center tab labels 4: Tab borders 8: Double tab height 16: Show 3D Solid mass properties |
