ACISHLRRESOLUTION system variable
Hidden line removal resolution
Specifies the smallest distance taken into consideration during Hidden Line Removal calculation. A negative value means that auto-calibration based on the size of the model will be used. This is highly recommended. When dealing with entities that have very small sizes the value can be set to 0.001 or smaller.
BricsCAD only
| Type: |
Real |
| Saved in: | Preference |
| Default value: |
-1.0 |
