ANNOTATIVEDWG system variable
Annotative drawing
Specifies whether or not the drawing will behave as an annotative block when inserted into another drawing. The ANNOTATIVEDWG system variable becomes Read-only if the drawing contains annotative entities.
| Type: |
Boolean |
| Saved in: | Drawing |
| Default value: | Off |
| Possible values: |
Off (0): Not annotative On (1): Annotative |
