ATTMODE system variable
Attribute display mode
Specifies whether attributes are visible or not. If the ATTMODE variable is set to 2, all attributes display, including Hidden attributes.
| Type: |
Short |
| Saved in: | Drawing |
| Default value: | 1 |
| Possible values: |
0: Don't show 1: As defined in block 2: Show all |
