AUTOMATICSTAIRSECTIONBEHAVIOR system variable
Automatic stair section behavior
If set to Symbolic, a symbolic representation of entities classified as Stairs will be generated during section generation. This will affect only the automatic stair sectioning behavior. To customize, launch the BIMGENERATE2DSTAIR command before sectioning.BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Default value: |
0 |
| Possible values: |
0: Symbolic 1: Geometric |
