BACKGROUNDPLOT system variable
Background plotting
Specifies whether background plotting is enabled for plotting and/or publishing. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: | Short |
| Saved in: | Registry |
| Range: | 0 to 3 |
| Default value: | 2 |
| Possible options: |
0: None 1: When plotting (Not supported) 2: When publishing |
