BIMDEFAULTPROPERTIESPATH system variable
Default properties path
The file paths for properties, loaded when a new document is opened.
Solo-BricsCAD
Tipo: |
Stringa |
Salvato in: |
Registro di sistema |
Valore predefinito: | bimproj_user.xml;bimproj_IFC2x3.xml;bimproj_IFC4.xml;bimproj_quantity.xml |
