BINDTYPE system variable
Xref bind type
Controls how XRefs names are handled when XRefs are bound or edited in place.
If on, uses insert-like behavior. If off, uses traditional bind behavior.
Tipo:
Booleana
Salvato in:
Non salvato
Valore predefinito:
0
Valori possibili:
Off (0): Traditional binding behavior
On (1): Insert-like behavior
  • If the BINDTYPE system variable = 1 (Insert-like behavior): Xrefs will be converted into blocks.
  • If BINDTYPE system variable = 0 (Traditional binding behavior): it binds the xref and makes the xref part of the drawing (the objects/layers from the external drawing will be added to the current drawing with the prefix equal to the file name).
