BOMFILTERSETTINGS system variable
Default BOM filter settings
Sets default filter settings to define which objects to include.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 127 |
| Default value: |
1 |
| Possible values: |
1: Include mechanical components, blocks and solids 2: Include non-mechanical local blocks and solids 4: Include non-mechanical external references 8: Include solid plies 16: Ignore BOM status 32: Treat external references as transparent 64: Treat leaf parts as transparent |
Note: If the file does not contain any mechanical components and the mode does not require to include any non-mechanical entities, then it will be extended to include all non-mechanical entities.
