CLIPBOARDFORMATS system variable
Clipboard Formats
Types of data that are supported when copying to the clipboard. Flags can be unchecked to improve performance. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 127 |
| Default value: |
127 |
| Possible options: |
1: Bitmap 2: Metafile Picture Format 4: Enhanced Metafile 8: AutoCAD.r14 16: BricsCAD 32: OLE Embed Source and Object Descriptor 64: CVS and XMLSS table data |
