CLIPROMPTLINES system variable
Prompt Lines
If the Command panel is not visible, the last few Command line entries are shortly displayed at the bottom of the main graphics window each time a command is entered. CLIPROMPTLINES specifies the number of lines to display. (set to zero to disable the feature).
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 64 |
| Default value: |
4 |
