CMDDIA system variable
Command dialogs
Specifies whether dialog boxes are turned on for commands.
BricsCAD only
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | On |
| Possible values: |
Off (0): Don’t use dialog box for commands On (1): Use dialog box for commands |
