CMDLINEEDITBGCOLOR system variable
Command line edit background color
Specifies the background color of the Command line's edit field. Color may be represented as a name (for standard colors) or as RGB values. At the Command line, color may be entered as a name (for standard colors), RGB values, or HTML color.
BricsCAD only
| Type: | String |
| Saved in: | Preference |
| Default value: |
50 54 56 (Settings dialog) #323638 (Command line) |
