CONTINUOUSMOTION system variable
Continuous motion
Specifies whether rotation continues after releasing the mouse when using the Realtime View Rotate command.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | Off |
| Possible values: |
Off (0): Disable continuous inertial motion in realtime On (1): Enable continuous inertial motion in realtime |
