CREATESKETCHFEATURE system variable
Sketch based feature (experimental)
Controls whether sketch based feature should be created in Extrude and Revolve commands.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Range: |
0 to 1 |
| Default value: |
0 |
| Possible values: |
0: Do not create sketch based feature 1: Create sketch based feature |
Note: This system variable can also be set by pressing the CreateSketchFeature toggle button
in the ribbon.
in the ribbon.The location of the toggle button depends on the loaded CUI file and the workspace:
- Classic interface
- Modeling workspace: Solid & Surface tabs > Direct Modeling ribbon panel.
Mechanical workspace: Solid & Surface tabs > Create ribbon panel.
- Modern interface
- Modeling & Mechanical workspaces: Home tab > Controls ribbon panel.
