DELETEINTERFERENCE system variable
Delete interference
Specifies whether interferences between source and other 3d solids are retained or resolved (i.e. source solids will be subtracted from any interfering solids).
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | On |
Valori possibili: |
Off (0): Don’t solve interferences after commands On (1): Solve interferences after commands |
