DGNIMPIMPORTVIEWINDEX system variable
Import view index
Controls the number of DGN views, level masks and view settings to use.
Values between -1 and 7 are accepted. -1 means that the view is not defined and view settings and level masks are not used.
Note: Microstation uses the word "level" for layers; a "mask" hides content in areas or levels/layers.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Preferenza |
Gamma: |
-1 to 7 |
Valore predefinito: |
-1 |
Valori possibili: |
-1: View is not defined 1 to 7: Specifies level mask |
