DIMARCSYM system variable
Arc symbol
Specifies how the arc length symbol displays in an arc dimension.
| Type: | Short |
| Saved in: | Drawing |
| Range: | 0 to 2 |
| Default value: | 0 |
| Possible values: |
0: Arc length symbol is placed before the dimension text 1: Arc length symbol is placed above the dimension text 2: The display of the arc length symbol is suppressed |
