DIMAZIN system variable
Suppress angle zeros
Suppresses leading and/or trailing zeros for angular dimensions. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: | Short |
| Saved in: | Drawing |
| Range: | 0 to 3 |
| Default value: | 0 |
| Possible options: |
1: Suppress leading zeros 2: Suppress trailing zeros |
