DIMBLK1 system variable
Arrow 1
Specifies the name of the block displayed at the first end of dimension line when DIMSAH is on (= use different blocks for the first and the second arrowhead).
Type: | String |
Saved in: | Drawing |
DIMBLK1 system variable - BricsCAD Lite & Pro | Centro Assistenza Bricsys
