DIMBLK2 system variable
Arrow 2
Specifies the name of the block displayed at the second end of dimension line when DIMSAH is on (= use different blocks for the first and the second arrowhead).
Type: | String |
Saved in: | Drawing |
Type: | String |
DIMBLK2 system variable - BricsCAD Lite & Pro | Centro Assistenza Bricsys
