DIMDLI system variable
Dim baseline spacing
Specifies the spacing between dimension lines in baseline dimensions.
Type: | Real |
Saved in: | Drawing |
Default value: | 3.8 |
Type: | Real |
DIMDLI system variable - BricsCAD Lite & Pro | Centro Assistenza Bricsys
