DIMLIM system variable
Tolerance method
Specifies the default text to dimension limits. If DIMLIM is On, DIMTOL is switched Off.
| Type: | Boolean |
| Saved in: | Drawing |
| Default value: | Off |
| Possible values: |
Off (0): Don’t generate dimension limits as default text On (1): Generate dimension limits as default text |
